farex@darkstar:~$ sudo smartctl --all /dev/sda
smartctl version 5.38 [i686-pc-linux-gnu] Copyright (C) 2002-8 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Device Model: ST31500341AS
Serial Number: 9VS32HMD
Firmware Version: CC1H
User Capacity: 1 500 301 910 016 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Sun Jun 13 11:07:08 2010 OMSST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 609) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x103f) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 104 099 006 Pre-fail Always - 7114865
3 Spin_Up_Time 0x0003 100 100 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 191
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 3
7 Seek_Error_Rate 0x000f 069 060 030 Pre-fail Always - 9387380
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 1490
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 191
184 Unknown_Attribute 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 091 091 000 Old_age Always - 9
190 Airflow_Temperature_Cel 0x0022 066 057 045 Old_age Always - 34 (Lifetime Min/Max 23/34)
194 Temperature_Celsius 0x0022 034 043 000 Old_age Always - 34 (0 16 0 0)
195 Hardware_ECC_Recovered 0x001a 051 041 000 Old_age Always - 7114865
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 103263898699218
241 Unknown_Attribute 0x0000 100 253 000 Old_age Offline - 1857805117
242 Unknown_Attribute 0x0000 100 253 000 Old_age Offline - 2123357024
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
farex@darkstar:~$
Гуигнгм, вы после вывода смарта, так легко откинули возможность что трабла может быть и системой, откуда такая уверенность то? Вот взгляните на вывод моего смарта.
И при таких показателях диск вполне нормально работает.
>Сразу видать уровень оппонента(с)farex
Толсто же.
К тому же если не поняли намека, то уж простите, я привык общаться с людьми уровень IQ которых не ниже 120ти. )=
Ваш уровень на вскидку 90~95., что же, вы не виноваты, природа мать ее обделила., но таких как вы много.
Зы: Модеров прошу забанить меня, иначе начну злобно тролить ы, общения здесь унижает мое ЧСВ.
Прощайте...
Я лет 6 пользую Самсунги, в данный момент в моем компе стоит 3 их диска, 640 и 2 по 1Тб
3,5 и 1,8 и 2,5
в чем разница жеского диска 3,5 и 1,8 и 2,5
