Expansion tank - brown color На страницу 1, 2 След. |
Автор | Сообщение | ||||||
Vuja![]() На форуме 9 лет
Авто: VAZ 21124 1,6 16 valves 2005. Talbot Simca Matra 1,6 8 v
Expansion tank received brown color. My car has never overheating but a couple times in city drive was at the edge of the red field temperature and then I turned on heating to reduce the temperature. I think that my machine is not mixed because oil and water because I don't have a loss of liquid and oil is clean, ie. no white deposits. What is the reason for brown expansion vessels? Bad plastic or a lack of cooling the engine? You may fan late start after the set for your Russian conditions? Give me some advice. Thanks! |
mr1![]() На форуме 12 лет
(ENG) Coolant acquired brown color from the fact that cast-iron cylinder block rzhaveet. This is not dangerous, and fight this useless. Just once in two years replace coolant. (RUS) Охлаждающая жидкость приобрела коричневый цвет от того, что чугунный блок цилиндров ржавеет. Это не опасно и бороться с этим бесполезно. Просто один раз в два года меняй охлаждающую жидкость. _________________ Нет иномарки - нет проблем. |
Vladogk На форуме 12 лет
Авто: ВАЗ 21124, 2005
It might be an unfortunate effect of ageing of the tank material (if your car is too old). You could have used low-quality antifreeze. You may have to substitute antifreeze for new one (with tank). Though, in itself brown color of a tank isn't a faultiness. Also in case of overheating you should chek the thermostat. Russian conditions are mainly from -35 to +35. |
Thanks for double answer (russian and engl)! ![]() |
Vlad B На форуме 12 лет
Kachan![]() На форуме 12 лет
right, and bad quality of tank lid (over-pressure): http://www.autolada.ru/viewtopic.php?t=156243 (filter ![]() http://www.autolada.ru/viewtopic.php?t=61996 ---> lid from audi, vw http://www.kvartsauto.ru/items/item694.htm http://www.autolada.ru/viewtopic.php?t=155360& http://www.autolada.ru/viewtopic.php?t=56816& http://www.autolada.ru/viewtopic.php?t=26777& http://www.autolada.ru/viewtopic.php?t=73895& |
egoIUBT![]() На форуме 12 лет
Авто: 21103
May be, but main reason of broken tanks is unproper internal pressure in the cooling system. Your friends has to check or replace tank cap at first. Brown powder inside of tank its time to change old antifreeze, but you have to wash your cooling system before fill it with new one. _________________ 21103, золотой лист |
leon112 Модератор ![]() ![]() На форуме 14 лет
Авто: мото, вело
Молодец парень, не сдается. Но русский - учи!!! (с)
Вот не надо ерунду говорить человеку. Переводите. Слей, то г...но, что залито в твою машину вместо ОЖ, дать двигателю остыть немного, предварительно завернув пробки слива, залить ключевой или дисцилированной воды, дать двигателю прогреться, затем еще раз слить. Купить промывку систему охлаждения двигателя залить ее вместе с очередной порцией воды. Дать поработать двигателю до рабочей температуры. Слить. Похорошему надо еще раз промыть водой, как первый раз. Купить концентрат антифриза Hepu разбавить его ключевой водой по инструкции, залить и радоваться жизни. Цвет не меняется не только в течение рекомендованных 3 лет, но даже и 5-ти лет. _________________ С уважением Сергей ![]() |
dmitriy_840![]() На форуме 12 лет
Авто: ВАЗ 21061, ВАЗ 21113
snow02rus![]() На форуме 12 лет
Авто: 10,11,17
Какую воду ни заливай, а чугун будет ржаветь по любому. Только аллюминиевые блоки не дают ржавого цвета охлаждающей жидкости. Но, повторяю, это не проблема. Меняй ОЖ согласно регламента и всё будет хорошо. _________________ Нет иномарки - нет проблем. |
Yes, I think like you. ![]() ![]() ![]() |
Gloom Chip 'n Dale типо))) ![]() На форуме 15 лет
use distilled water _________________ ВАЗы есть везде, где-то для цветов, а где то на них ездят. www.asgloom.narod.ru |
For good cleaning I need minimum 10 - 15 lit distilled water and compresor for big push. I haven't condition for this operation. For my old car I use water pressure from the city's water supply. ![]() |
Авто: мото, вело
+1 Не нужен ему никакой компрессор. Необходимо промыть раза два три, один раз с промывкой. И залить хороший антифриз!!! Я так понял товарищ понимает и наш русский и наш ломанный английский. Молодец!!! Респект!!!.
В основном - мягкая. Но для промывки это и не важно. А в хорошем концентрате есть присадки убирающие жесткость воды. У меня уже чуть больше 3 лет антифриз Hepu, ничего не ржавеет. Так что не надо говорить ерунду. _________________ С уважением Сергей ![]() |
Авто: мото, вело
RushTonop На форуме 9 лет
Авто: ВАЗ-21113 Я5.1.2 2002г.в.
I have done it with help of MikeS, Ilnur: http://www.autolada.ru/viewtopic.php?t=156243 . New antifreeze is blue as a sky ![]() ![]() |
Не нужен ему никакой компрессор. Необходимо промыть раза два три, один раз с промывкой. И залить хороший антифриз!!! Я так понял товарищ понимает и наш русский и наш ломанный английский. Молодец!!! Респект!!! Привет друг, Я понимаю русский, но не знаю, писать. Я знаю Английский и французский языки, но я никогда не узнал русский. Когда я был официально в Беларуси общаться и на русском языке и Английский. Привет
В основном - мягкая. Но для промывки это и не важно. А в хорошем концентрате есть присадки убирающие жесткость воды. У меня уже чуть больше 3 лет антифриз Hepu, ничего не ржавеет. Так что не надо говорить ерунду. Не строгие. Моя ВАЗ три года и она является оригинальной антифриз еще появилась ржавчина. |
IMHO - 3 years, maybe its time to change antifreeze |
Часовой пояс: GMT + 4 |
