Ken13
вроде простая игруха (по сети). Смесь аэрохоккея и футбола, а полный ноль в ней ))) Затягивает!
Управление стрелками. Удар Cntrl или Пробел
Создал комнату Autolada's Room
пароль 13
присоединяйтесь
http://haxball.com/
Dmi
Failed to connect Pardon
Ken13
Dmi писал(а):
Failed to connect
есть там такое...в FAQ написано что и как. Я на 90% серверов не могу попасть
Димoн
Работает!
Ken13
Димoн
давай играй Smile сейчас плюху закину. Кстати, там можно толпой. 4 на 4 к примеру
Димoн
Херь какая-то я никуда попасть не могу. pst
Ken13
тренируйся
jorik
+1 cry и фак на аглицком блин
Димoн
чем больше народу тем лучше!
Meffex
Куда-то комната пропала...
А ваще ничо так Smile
так ты из сисек вылези,увидиш комнату 63
Димoн
я тоже комнаты не вижу!
Ken13
shmayselez
че та не подключается
Ken13
там какая-то хрень с роутерами
I can't connect to any rooms! It gets stuck at the "Connecting to host" phase.
If you're experiencing problems connecting to host then you are one of the unfortunate few people who have evil routers.
The reason you have this problem is because the NAT hole punching tech used to make P2P connections in Flash is not compatible with your network topology. This is not a problem with the game, it is a problem with Flash, there is nothing the dev can do about it.
Players have reported a few ways to solve this problem:
-Forwarding all the UDP ports in the range 1024..65535 (a lot I know, Flash will pick one at random from that range).
-If you are behind two routers enable UPnP in the first one.
-Configure your router to point to your computer as a DMZ host.
-Removing your router from the equation entirely and connect directly to the internet.
-If you are unable to enact the above fixes, don't worry, there are some hosts that you will always be able to connect to, make sure to try every game available. You will be able to connect to at least one of them.
If you find any method to fix this that isn't mentioned in this FAQ please let us know and we'll add it here.
lml-83
Ken13
сейчас попробую
lml-83
что то думает долго
disconnect cry
Ken13
Вчера удавалось зайти Meffex, Dimon, некий Jo вечером. Играли 2*2 чуток. Интересно. Можно и командами 4*4 или 5*5
lml-83
что то я вообще не могу зайти ни к кому
shmayselez
2 дня уже не работаю gpn
Ken13
AlexYur555
Не заходит. По англ не шарю. Че как настроить...
Ken13
AlexYur555
бывает. Попробуй сам создай комнату Create Room
только password напиши тут и ссылку
AlexYur555
AlexYur555"s Room пароль 14
AlexYur555
Ken13
Заходи, давай пробовать
