Иногда Михалыча78 становится много. facepalm
Я даже нашел вам мод как ограничить кол-во его постов в сутки.
Готов всячески содействовать в установке и настройке это мода. supercool
Код:
## MOD Title: Limit Posts At Topic By Time
## MOD Author: [R: R@m$e$ :U] < phpBB@Ramses.us > (Ramses) http://www.Ramses.us
## MOD Description: Limits number of posts by user at each topic, eg.
##      3 posts at 1 week for topic
## MOD Version: 1.0.0
## Installation Level: Easy
## Installation Time: ~10 Minutes
## Files To Edit:
##      includes/constants.php
##      includes/functions_post.php
##      language/lang_english/lang_admin.php
##      language/lang_english/lang_main.php
## Included Files:
##      root/db_update.php
## License: http://opensource.org/licenses/gpl-license.php GNU Public License v2
## For security purposes, please check: http://www.phpbb.com/mods/
## for the latest version of this MOD. Although MODs are checked
## before being allowed in the MODs Database there is no guarantee
## that there are no security problems within the MOD. No support
## will be given for MODs not found within the MODs Database which
## can be found at http://www.phpbb.com/mods/
## Author Notes:
##      Find bug or write new translation? Please write me...
##      Translations to other languages you can find at "./Translations"
##      Run SQL-commands in phpMyAdmin or execute root/db_update.php
##      !!! IMPORTANT !!!
##      !! If you not bought this MOD, please, write me...         !!
##      !! You can levae this MOD for your use,                    !!
##      !! But user (and his site) which break my copyrights,      !!
##      !! will be ignored by phpBB Community...                   !!
##      !! You can't publicate this MOD or using on site which I'm !!
##      !! not permitted!                                          !!
##      !! Please, be honest =)                                    !!
## MOD History:
##   2005-12-12 - Version 1.0.0
##      - Initial release...
## Before Adding This MOD To Your Forum, You Should Back Up All Files Related To This MOD
#-----[ SQL ]------------------------------------------
INSERT INTO phpbb_config VALUES ('limit_posts', '3');
INSERT INTO phpbb_config VALUES ('limit_time', '7');
CREATE TABLE phpbb_posts_time (
  user_id MEDIUMINT(8) NOT NULL DEFAULT '0',
  topic_id MEDIUMINT(8) NOT NULL DEFAULT '0',
  time INT(11) NOT NULL DEFAULT '0',
  posts SMALLINT(4) NOT NULL DEFAULT '0'
) TYPE=MyISAM;
#-----[ OPEN ]------------------------------------------
admin/admin_board.php
#-----[ FIND ]------------------------------------------
<?php
#-----[ AFTER, ADD ]------------------------------------------
/*** -= Limit Posts At Topic By Time v1.0.0 by [R: R@m$e$ :U] =- ***/
   "L_ENABLE_GZIP" => $lang['Enable_gzip'],
   // [start] Limit Posts At Topic By Time
   "L_LIMIT_POSTS" => $lang['Limit_posts'],
   "L_LIMIT_TIME" => $lang['Limit_time'],
   // [end] Limit Posts At Topic By Time
   "GZIP_YES" => $gzip_yes,
   "GZIP_NO" => $gzip_no,
   "LIMIT_POSTS" => $board_config['limit_posts'],
   "LIMIT_TIME" => $board_config['limit_time'],
<?php
define('POSTS_TEXT_TABLE', $table_prefix.'posts_text');
define('POSTS_TIME_TABLE', $table_prefix.'posts_time');
<?php
               message_die(GENERAL_MESSAGE, $lang['Flood_Error']);
   if ( $mode == 'reply' && $userdata['session_logged_in'] == 1 )
      if ( ($board_config['limit_posts'] > 0) && ($board_config['limit_time'] > 0 ) )
         $sql = 'SELECT *
            FROM ' . POSTS_TIME_TABLE . '
            WHERE user_id = ' . $userdata['user_id'] . '
               AND topic_id = ' . $topic_id . '
            LIMIT 1';
         if ( !($result = $db->sql_query($sql)) )
            message_die(GENERAL_ERROR, 'Could not obtain time limits information', '', __LINE__, __FILE__, $sql);
         if ( $db->sql_numrows($result) > 0 )
            $row = $db->sql_fetchrow($result);
            if ( ($row['time'] + ($board_config['limit_time'] * 86400)) < time() )
               $sql = 'UPDATE ' . POSTS_TIME_TABLE . '
                  SET time = ' . time() . ', posts = 1
                     AND topic_id = ' . $topic_id;
                  message_die(GENERAL_ERROR, 'Could not update time limits information', '', __LINE__, __FILE__, $sql);
            else
               if ( $row['posts'] >= $board_config['limit_posts'] )
                  $message = sprintf($lang['Limit_posts_exceed'], $board_config['limit_posts'], $board_config['limit_time']);
                  message_die(GENERAL_ERROR, $message);
               else
                     SET posts = ' . ($row['posts'] + 1) . '
         else
            $sql = 'INSERT INTO ' . POSTS_TIME_TABLE . ' (user_id, topic_id, time, posts)
               VALUES(' . $userdata['user_id'] . ', ' . $topic_id . ', ' . time() . ', 1)';
               message_die(GENERAL_ERROR, 'Could not insert time limits information', '', __LINE__, __FILE__, $sql);
<?php
#-----[ BEFORE, ADD ]------------------------------------------
$lang['Limit_posts'] = 'Limit post count per topic';
$lang['Limit_time'] = 'Limit time between post\'s limit per topic';
<?php
$lang['Limit_posts_exceed'] = 'You have exceeded the number of posts (%s) for this time limit (%s Days)';
templates/subSilver/admin/board_config_body.tpl
{GZIP_NO}
</tr>
   <!-- [start] Limit Posts At Topic By Time //-->
   <tr>
      <td class="row1">{L_LIMIT_POSTS}</td>
      <td class="row2"><input class="post" type="text" name="post_limit" size="3" maxlength="4" value="{LIMIT_POSTS}" /></td>
   </tr>
   <tr>
      <td class="row1">{L_LIMIT_TIME}</td>
      <td class="row2"><input class="post" type="text" name="time_limit" size="3" maxlength="4" value="{LIMIT_TIME}" /></td>
   </tr>
   <!-- [end] Limit Posts At Topic By Time //-->
#-----[ SAVE/CLOSE ALL FILES ]------------------------------------------
# EoM
pst
Добавлено спустя 4 минуты 15 секунд:
TYPE=MyISAM замените на ENGINE=MyISAM supercool
Mihalych78
Огурец с утра кислый попался? pst
Не, ну вы видели, он и тут успел насрать facepalm
maxiz
хм... уздечка для Михалыча ROFL
он и ее порвет в бою за свободу срать в песочнице 63
Mihalych78
если меня много - я уйду
но тогда вас замучает своим бредом этот гений скрипта
сейчас он мне ничего противопоставить не может
вот и мается pst
Mihalych78
Если ты уйдешь, я обещаю постить не более 5 сообщений в день.
Теперь давай проверим кто из нас держит слово! А кто из нас клоун оренбургский Wink
maxiz
да сиди уж, болезный ppc
А то Анжела вон уже сколько уходит, да ток воз и ныне тут hehe
Mihalych78
ннннеее
я правда уйду
но тогда ЛОЛ превратится в огуречную теплицу ROFL
Mihalych78
Ты ещё здесь?
Art_16R
он и ее порвет
Уздечка - это которая на йенге? wwow
Mihalych78
Art_16R писал(а):
он и ее порвет
Зубиловод так хвостик огурцов называет
коими они к грядке крепятся hehe
maxiz
Art_16R писал(а):
он и ее порвет
Ну Михалыч, навер, в потугах ту уже давно порвал pst
BPSNSK
MINOGUS
