zulian
Good day,
I have only a black key for my 111.
I lost the red key.
Without red key , I'm unable to make a new key.
Do you have an idea to make a new electronic key whitout red key ?
or
Is it possible "to shunt" the system of anti-starting?
Frédéric ZULIAN
http://www.zulian.com/dala/indexrusse.html
У меня черный ключ для мой 111.
Я потерял красный ключ.
Без красного ключа, невозможного делать новый ключ.
Имеете ли Вы идею чтобы делать электронный ключ?
Возможен ли он " Shunter " система анти-пуска?
Андрей_П
zulian
Hello.
You can't make new black key or switch anti-starting system in valet mode without red key.
In you case need replace anti-starting system AND electronic controller of engine.
Or erase flash ROM in controller of engine and disconnect anti-starting system from it. In this case you can start the engine without black key.
Best regards,
Andrey
zulian
Hello,
Thanks for your answer.
There is not a bit dangerous to erase the flash ROM in controller of engine ?
I'm afraid to put out of order the calculator of injection.
Best regards
zulian
Arrghhh, ...............
- To erase flash ROM in controller of engine I must buy the special software from BOSCH !!!!
