## MOD Title: Limit Posts At Topic By Time
## MOD Author: [R: R@m$e$ :U] < phpBB@Ramses.us > (Ramses) http://www.Ramses.us
## MOD Description: Limits number of posts by user at each topic, eg.
## 3 posts at 1 week for topic
## MOD Version: 1.0.0
## Installation Level: Easy
## Installation Time: ~10 Minutes
## Files To Edit:
## includes/constants.php
## includes/functions_post.php
## language/lang_english/lang_admin.php
## language/lang_english/lang_main.php
## Included Files:
## root/db_update.php
## License: http://opensource.org/licenses/gpl-license.php GNU Public License v2
## For security purposes, please check: http://www.phpbb.com/mods/
## for the latest version of this MOD. Although MODs are checked
## before being allowed in the MODs Database there is no guarantee
## that there are no security problems within the MOD. No support
## will be given for MODs not found within the MODs Database which
## can be found at http://www.phpbb.com/mods/
## Author Notes:
## Find bug or write new translation? Please write me...
## Translations to other languages you can find at "./Translations"
## Run SQL-commands in phpMyAdmin or execute root/db_update.php
## !!! IMPORTANT !!!
## !! If you not bought this MOD, please, write me... !!
## !! You can levae this MOD for your use, !!
## !! But user (and his site) which break my copyrights, !!
## !! will be ignored by phpBB Community... !!
## !! You can't publicate this MOD or using on site which I'm !!
## !! not permitted! !!
## !! Please, be honest =) !!
## MOD History:
## 2005-12-12 - Version 1.0.0
## - Initial release...
## Before Adding This MOD To Your Forum, You Should Back Up All Files Related To This MOD
#-----[ SQL ]------------------------------------------
INSERT INTO phpbb_config VALUES ('limit_posts', '3');
INSERT INTO phpbb_config VALUES ('limit_time', '7');
CREATE TABLE phpbb_posts_time (
user_id MEDIUMINT(8) NOT NULL DEFAULT '0',
topic_id MEDIUMINT(8) NOT NULL DEFAULT '0',
time INT(11) NOT NULL DEFAULT '0',
posts SMALLINT(4) NOT NULL DEFAULT '0'
) TYPE=MyISAM;
#-----[ OPEN ]------------------------------------------
admin/admin_board.php
#-----[ FIND ]------------------------------------------
<?php
#-----[ AFTER, ADD ]------------------------------------------
/*** -= Limit Posts At Topic By Time v1.0.0 by [R: R@m$e$ :U] =- ***/
"L_ENABLE_GZIP" => $lang['Enable_gzip'],
// [start] Limit Posts At Topic By Time
"L_LIMIT_POSTS" => $lang['Limit_posts'],
"L_LIMIT_TIME" => $lang['Limit_time'],
// [end] Limit Posts At Topic By Time
"GZIP_YES" => $gzip_yes,
"GZIP_NO" => $gzip_no,
"LIMIT_POSTS" => $board_config['limit_posts'],
"LIMIT_TIME" => $board_config['limit_time'],
<?php
define('POSTS_TEXT_TABLE', $table_prefix.'posts_text');
define('POSTS_TIME_TABLE', $table_prefix.'posts_time');
<?php
message_die(GENERAL_MESSAGE, $lang['Flood_Error']);
if ( $mode == 'reply' && $userdata['session_logged_in'] == 1 )
if ( ($board_config['limit_posts'] > 0) && ($board_config['limit_time'] > 0 ) )
$sql = 'SELECT *
FROM ' . POSTS_TIME_TABLE . '
WHERE user_id = ' . $userdata['user_id'] . '
AND topic_id = ' . $topic_id . '
LIMIT 1';
if ( !($result = $db->sql_query($sql)) )
message_die(GENERAL_ERROR, 'Could not obtain time limits information', '', __LINE__, __FILE__, $sql);
if ( $db->sql_numrows($result) > 0 )
$row = $db->sql_fetchrow($result);
if ( ($row['time'] + ($board_config['limit_time'] * 86400)) < time() )
$sql = 'UPDATE ' . POSTS_TIME_TABLE . '
SET time = ' . time() . ', posts = 1
AND topic_id = ' . $topic_id;
message_die(GENERAL_ERROR, 'Could not update time limits information', '', __LINE__, __FILE__, $sql);
else
if ( $row['posts'] >= $board_config['limit_posts'] )
$message = sprintf($lang['Limit_posts_exceed'], $board_config['limit_posts'], $board_config['limit_time']);
message_die(GENERAL_ERROR, $message);
else
SET posts = ' . ($row['posts'] + 1) . '
else
$sql = 'INSERT INTO ' . POSTS_TIME_TABLE . ' (user_id, topic_id, time, posts)
VALUES(' . $userdata['user_id'] . ', ' . $topic_id . ', ' . time() . ', 1)';
message_die(GENERAL_ERROR, 'Could not insert time limits information', '', __LINE__, __FILE__, $sql);
<?php
#-----[ BEFORE, ADD ]------------------------------------------
$lang['Limit_posts'] = 'Limit post count per topic';
$lang['Limit_time'] = 'Limit time between post\'s limit per topic';
<?php
$lang['Limit_posts_exceed'] = 'You have exceeded the number of posts (%s) for this time limit (%s Days)';
templates/subSilver/admin/board_config_body.tpl
{GZIP_NO}
</tr>
<!-- [start] Limit Posts At Topic By Time //-->
<tr>
<td class="row1">{L_LIMIT_POSTS}</td>
<td class="row2"><input class="post" type="text" name="post_limit" size="3" maxlength="4" value="{LIMIT_POSTS}" /></td>
</tr>
<tr>
<td class="row1">{L_LIMIT_TIME}</td>
<td class="row2"><input class="post" type="text" name="time_limit" size="3" maxlength="4" value="{LIMIT_TIME}" /></td>
</tr>
<!-- [end] Limit Posts At Topic By Time //-->
#-----[ SAVE/CLOSE ALL FILES ]------------------------------------------
# EoM
Иногда Михалыча78 становится много.
Я даже нашел вам мод как ограничить кол-во его постов в сутки.
если меня много - я уйду
уздечка для Михалыча
он и ее порвет
он и ее порвет
он и ее порвет
